cluster goes NUTS!
Old Jul 17, 2008 | 06:14 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
cluster goes NUTS!
when i turn my headlights on my gauge cluster does nuts for about 5 mins then is fine...it only happens when i turn the lights on...anyone have this problem?...im guessing its not normal....
Old Jul 18, 2008 | 10:22 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: cluster goes NUTS!
anyone??
Old Jul 19, 2008 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Replace the headlight switch?
JamesC
Old Jul 19, 2008 | 08:39 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
JamesC
probably not
be a little more specific on what its doing
are some gauges shorting out? either dieing or maxing out (or both)
if thats what its doing then the first thing i would tell you to try is to tighten snugly, but not too tight. the screws that go around the perimiter of the cluster.
from what it sounds its not getting a good connection and after a little driving its just getting the little bump it needs from road conditions to put it just where it needs to be.
Old Jul 19, 2008 | 09:13 AM
JamesC's Avatar
If the cluster functions normally without the lights and only fails when they're turned on, reason would say that the problem originates at the switch (but then reason sometimes goes out the window).
JamesC
Old Jul 19, 2008 | 10:55 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
JamesC
Could be, but in my case the contacts behind my cluster just needed to be reseated properly to get a good connection
Old Jul 20, 2008 | 10:58 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
it seems like the cluster goes bonkers when i hit bumps...all is good for the most part then when i hit a bump the cluster goes awall...when the lights are off it works perfectly fine no glitches at all...im guessing it might be a bad ground somewhere?...but any more help would be appreciated
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
3.8TransAM
Sep 27, 2015 08:37 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
