Fuel Pump Circuit Voltages table?
Old Jul 23, 2008 | 11:57 PM
IroczInOz's Avatar
Can someone please point me into the right direction where I can find a list of correct voltages for the fuel pump circuit?
I am after the fuel pump relay and the fuel pump connector voltages.
Old Jul 24, 2008 | 12:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel Pump Circuit Voltages table?
+12V whenever power to the pump is on.
Old Jul 24, 2008 | 02:50 AM
IroczInOz's Avatar
Would the pump run at 11v?
I have made a funny discovery and am wondering what could cause this. If you have a spare 5min can you check it out to see what you think.
Under TPI Forum - Fuel pressure playing up New AFPR did not solve the problem.
Old Jul 24, 2008 | 02:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll run at less than that even.
Old Jul 24, 2008 | 03:01 AM
IroczInOz's Avatar
Interesting well I hope my voltage is low as that is the only thing other then the pump dying. I seem to be having fuel pressure probs and looks like a lack of flow from the pump.
There is a test that you undo the fuel line at the motor run the pump for 15 seconds and you are supposed to get x amount of fuel. If the voltages check out fine above 12+ my last option is to replace pump.
Just that the headlight thing bugs me. Turn headlights on and 4psi drops off from the fuel pressure.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
