HELP, TURN ON MY LIGHTS GAUGE CLUSTER GOES DIM,VOLT&OIL GAUGE STOPS WORKING?
Old Jul 29, 2008 | 09:59 AM
tripingeorge3's Avatar
85 iroc z .if i turn on my lights it my dash lights work fine for 2 mins. ten my rpm and gas gauge lights go dim and also my volt gauge and oil gauge stop completely. if i dim the lights i start getting readings, but their not correct. so right now i drive it with the dash lights off. anybody have any ideas.
Old Jul 29, 2008 | 10:11 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: HELP, TURN ON MY LIGHTS GAUGE CLUSTER GOES DIM,VOLT&OIL GAUGE STOPS WORKING?
Bad ground? sort of woerking alternator?
Old Jul 29, 2008 | 10:16 AM
the alt is still charging, i have a capacitor w/voltage gauge behind my seat.
Old Jul 29, 2008 | 10:39 AM
Car: 1992 RS 6spd
Maybe your guage cluster is shorting out. Did you run any REM wires to your guage cluster fuse? Or maybe something is reading the wrong resistance? Oh and FYI, your capacitor might have a regulator in it which is cutting volts to be read on your LED screen, there for not giving you an accurate reading. Put a DVM on the battery with the car running, you should be getting between 13.5 to 14.5 put back into the battery with a properly working Alternator. Turn on your gauge lights during this same test and see if it fluctuates.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
