Help please
Old Aug 1, 2008 | 09:07 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Help please
I have a problem with or my harness or relays, Im not sure.
I have a rebuilt 350 for my 87 GTA TPI auto, all sensors are new.
Hooking up a scan tool to my car and getting wack readings, engine didnt run, so I found my maf relay wasnt powering the maf so thats fixed, engine runs but not 100% smooth.
Scan tool is giving me some weird readings, car is parked on idle reading jumps, rpm 0000 to 3000, kmh at 000 to 255, ipw from 1.2 to 8.3 maf 8g to 200g, tps at 6.
Im starting to think my car is possessed, one moment it seems to give good readings then when I think all is well it craps out on me.
This has been a problem for a while now, just not sure if anyone has come accross such a problem.
Old Aug 2, 2008 | 07:53 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Re: Help please
Yea definantly possesed! I would think it could be anything that is doing that. Erratic fuel pressure, spark problems, sensor errors... Just start with one system and check and double check to make sure it is working correctly. If it is then move on to the next system and try.
If I had to guess I would say your maf is bad. If you know someone that you can swap with for a quick try do that. Have you checked and or replaced your tps sensor?
Old Aug 3, 2008 | 02:48 AM
transamice's Avatar
Car: 87 GTA t-top
Re: Help please
I have swapped mafs, computers, sensors are new, check the harness from the sensors to the computer.
I wouldnt say Im not best at doing it so I let my mechanic figure it out and even he doesnt know what the deal is.
Going to try a diff harness this week.
Old Aug 3, 2008 | 08:07 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Re: Help please
Have you messed with the idle air control motor? If that is freakin out it will allow air to randomly enter and then close it off. This will make your computer jump around along with the idle. Just a thought.
Old Aug 3, 2008 | 08:54 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Help please
IAC is new, acts same with old and new.
Old Aug 3, 2008 | 09:46 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Re: Help please
try posting this in the prom section or the ecm section. They may know how to diagnose the erratic readings youre getting off the scanner. Im not familiar with the scanner diagnosis.
Old Aug 3, 2008 | 10:03 PM
timeflyere6's Avatar
Car: 1992 camaro rs 25th aniversery
Engine: crapy 305 tbi
Transmission: blown 700r4
Axle/Gears: stock
Re: Help please
dome idea probably but u said u changed the ecm is that just the chip or whole things second it could be ur ob1 hook up is bad dirty so ur getting messed reading? then giving on all aspects its in ur ecm because to have all those problems it be like having a loose ground so when bumped it causes week conection across the board or something lol dude ur sol
