Choke light, blown fuse...hood scoop?!!
Old Aug 13, 2008 | 08:53 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
1984 T/A 305 4bbl (H). First smelled a wire cooking, then a mile or so later the choke light comes on. Choke relay buzzing when its cold. Fuse is blown. Couple weeks go by of fiddling as well as a handful of fuses. Not the alternator, not the choke, not the choke relay, not the high idle solenoid, not high idle relay, not the oil pressure switch. Finally after pouring through wiring diagrams, unplugged the wire lead going up to the power bulge hood vent from the vacuum switch. That was it.
Old Aug 21, 2010 | 07:10 PM
bart0977's Avatar
Car: 1984 Trans Am
Engine: 305 H.O. 4bbl.
Transmission: 5 speed manual
Axle/Gears: 3.73 Posi
Re: Choke light, blown fuse...hood scoop?!!
I recently performed the test to see if my hood solenoid worked, and when i pulled the vaccum line from the vaccum switch, the wire going to the solenoid got extremely hot and started smoking almost instantly. When I applied vaccum again, the wire went back to normal temperature. Then I tested the hood solenoid with 12 volts separately and it did not work. Would this mean that the solenoid is probably shorted out and this is the only broken component? I don't know what else to test to see if there is more wrong than just the hood solenoid. I'd like to get it working since the entire car (84 T/A) is completely original with 61,000 miles. Is there something else that I should test? Help. Thanks.
Old Aug 22, 2010 | 12:51 PM
ACCLR8N's Avatar
That would be my guess. Does the flapper and linkeage move freely?
Old Aug 22, 2010 | 03:16 PM
bart0977's Avatar
Car: 1984 Trans Am
It sure does. I also saw a post somewhere on this forum about rebuilding the solenoid. I'm going to make sure there is correct voltage to the wire harness and then pull the solenoid and see what I can do. In the mean time, I'll prop the flap open and see how the car performs. Others seem to report the car accelerates better than ever after removing the flap.
Ghettobird52
Jul 5, 2024 11:18 PM
Mutillator
Sep 17, 2015 04:38 PM
fasteddi
Sep 10, 2015 09:32 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Omega
Aug 10, 2015 12:46 PM
