Fuel pump fuse location
Old Aug 16, 2008 | 06:26 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Can anyone tell me exactly where the fuse is located or post a picture? I know it's supposed to be by the battery but i can't seem to find mine. Is it an inline fuse or a fuseable link? 89 IROC 5.7 TPI.
Old Aug 16, 2008 | 07:13 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Fuel pump fuse location
the fuse near the batt. is for the ecm not the f/p.
Its in a small black conn. thats held to the inner wheel well w/ one screw.
Slide the conn. off and theres the fuse.
Old Aug 16, 2008 | 09:37 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Is that the pass. side fenderwell?
Old Aug 16, 2008 | 05:55 PM
CamaroRider's Avatar
Yes, the passenger side. It is on the end of a harness, all by itself. Very near the battery. There is a plug with a cover an there is a fuse inside. In my Haynes 1989 Camaro manual the fuse is related to the ECM and the Fuel Pump.
Old Aug 16, 2008 | 07:48 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Thank's for your help guys,I will take a look in the morning and see if i can find it.
Mark
Old Aug 19, 2008 | 10:25 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I have to correct Timmy. The fuse by the battery IS for the ECM, Fuel Pump and Electric Fan(s).
It should be 20A or 25A (can't recall right now).
Lou
Old Aug 21, 2008 | 08:38 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Thank's for all your help guys, I finally found it. It was located between the battery and the radiator and it was blown, replaced it and fuel pump works.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
