Rigging starter...
Old Aug 18, 2008 | 05:34 AM
Kryppy's Avatar
Car: 87 Camaro
Engine: V-6 MPFI 2.8 liter
Transmission: 700 R4
Rigging starter...
I am at a complete loss why my Camaro wont start. (If you want more info. u can look at my posts on the V6 forum). Basically I am getting power from the main big black wire running from the batt. to the big bolt on the starter solenoid (there is juice there always as there should be.) I am not getting any power from the smaller purple wire that connects to the smaller bolt on the solenoid when I turn the key to start position for whatever reason. I was under the impression though if I just ran another wire connected to the pos. term. of the batt. & touched it to the smaller solenoid bolt or both bolts on the starter solenoid it would crank. Am I wrong in thinking this? I guess I must be cuz I tried it & nothing. Thank u for taking the time to read this & any input at all will be greatly appreciated. Thanx!
Old Aug 18, 2008 | 07:55 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Rigging starter...
It should crank if you either:
-put 12 volts to the purple wire
-cross the two larger terminals with a metal object (BE CAREFUL)
Old Aug 20, 2008 | 03:30 AM
Kryppy's Avatar
Car: 87 Camaro
I tried & it does not work. I tried with 3 dif. starters to make sure it was not a bum starter. What does this mean? Somebody please help! Ive already lost my job over this & I am about to get evicted if I cant fix this soon.
Old Aug 21, 2008 | 11:01 AM
Toehead's Avatar
Then the starter can't be getting power!
Maybe the ground strap for the block is not right. Check to make sure the starter has power!
RenoLB8
Mar 25, 2025 04:10 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Fox118
Sep 1, 2015 04:07 PM
Josh 91RS
Aftermarket Product Review
Dec 11, 2000 09:19 PM
Black Beauty
Dec 2, 2000 09:19 AM
