What is the Ac Delco part number for the GM relay 14078907
Old Aug 25, 2008 | 07:50 AM
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
What is the Ac Delco part number for the GM relay 14078907.
I can't find it on the AC Delco Web Page because i am not a member...well i gess.
Old Aug 25, 2008 | 10:11 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: What is the Ac Delco part number for the GM relay 14078907
That number supercedes to a GM# 10094701 and the delco number is 212-305
Old Aug 25, 2008 | 10:21 AM
sleeper383's Avatar
Engine: 5.0L
That's why the dealer told me this morning that part number (14078907) was no more available
Thanks!
Old Aug 25, 2008 | 10:52 AM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
i JUST replaced this (is it ur fuel pump relay?) go to autozone/checker or any parts store. then have them give them that #, 14078907 , and tell them to cross reference it. if u can, take ur old 1 with u (dont let them use its #) cause the 1 in their book 4 our car is is like oval but the 1 we need is square.
Old Aug 25, 2008 | 09:37 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
yeah, the original number on the relay is what they sometimes call an "engineering" number, and the service part number is different. it took me about 5 seconds at work to figure out the right number (i work at a GM dealership in parts)
Old Aug 27, 2008 | 11:27 AM
sleeper383's Avatar
Engine: 5.0L
O.K. now the good part because the ACDelco relay is no more available (GM Dealer), I bougt the Standard or Bleu Streak (same part number) RY-121 it replace application GM part with O.E.M number 10094701.
Everything work fine now
The only thing I’m confused with is the fact that some application use this relay for the fuel pump and sometimes other application and in my application it is use for the electric radiator fan
The person at the GM dealer gave me the part number 14078902 ACDelco p/n 15-8218 for the V8 Camaro radiator fan, it's a 4 connector relay and the one i have O.E.M 10094701 is 5 connector.
Thank you all!
Old Sep 13, 2009 | 09:36 PM
85berlinettabuf's Avatar
Car: 85 Camaro,05 Escape
Engine: v6 2.8 ltr,3.0 ltr
Transmission: m5
i am having the same problem , mine is a 5 pin connector and all i can find is a 4 pin but i did have a guy with a G M refference book check it for me on the weekend at a big automotive fleamarket and he says the blue streak # RY121 should replace the old 14078907 the extra pin is a extra ground wire ... going to buy this relay this week
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
