Help with Berlinetta wiring
Old Sep 14, 2008 | 10:08 AM
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
I brought a 84 berlientta with the 2.8 in it to convert into a 350 carb car. the wiring on the orginial car was shot so i went with the Summit racing wiring harness. so far i have the tail section done and most of the motor section complete except a few main things.
I need to wire in the wiper motor
and the a/c compressor
i had brought a iroc camaro wiring harness for the interior of the car so i can setup the iroc gauges and such but did not get the outside wiring harness and am currently usuing the stock 84 wiring harness and using it for its plugs to connect my other componets.
does anyone have a berlinetta wiring diagram or can tell me how to hook up the wipers for the berlinetta and slice those wires to make the wipes and a/c work
please write back
this is the only thing holding me up from completing the wiring in my car
thanks
scott
Old Sep 16, 2008 | 12:22 PM
Car: 84 Camaro
Re: Help with Berlinetta wiring
Bump Anyone kno anything about it?
Old Sep 17, 2008 | 08:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It will be quite a challange to get the Berlinetta heater system working when trying to use a "regular" Camaro interior harness. The Berlinetta heater system is electronicly controlled - but the Camaro system useses cables to operate.
When swapping from a Berlinetta interior to a "regular" Camaro interior I ALWAYS remove the Berlinetta heater system wiring harness and replace it with one from a regular Camaro. There is no easy way to make the Camaro system work using the Berlinetta componants.
When it comes to your Wipers - Here's what I did on my 85 Berlinetta conversion: ( Berlinetta engine harness - IROC interior harness ) You will need to cut the wiper plugs from a regular camaro with as much wiring as possible. You wil also need to replace the wiper motor with one from a normal camaro. Install the 'regular" wiper motor,.... lead the wiring thru the firewall. Then cut the wiper wiring that leads to the C100 connector and splice your wires into the interior (dash) harness.
I've got a CD with all the Berlinetta wiring diagrams ( I've also got a regular Camaro heater system harness as well.) If your interested in buying a copy just send me a PM for details.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
bbernardo94
Aug 19, 2015 05:25 AM
