lost
Old Oct 7, 2008 | 10:04 PM
socalred86z28's Avatar
lost
i have an 86 z28 and i'm having some start up problems.. heres the prob if my car sits for about a day or two it wont turn on unless i get curent from another car to my battery.. i took it to autozone they checked my battery they said it was fine checked my alternator and said it was fine.. now i have no idea wat it could be. its weird one day it will be fine but if it sits for a couple days i get no power and it wont turn on it seems like my battery is getting sapped. ne ideas??
Old Oct 7, 2008 | 10:39 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: lost
Something must be shorted allowing current to flow even if the car is turned off. Kind of like leaving the lights on, only it must be something else or you would have noticed the lights being left on.
To test this theory you could disconnect the battery when letting it sit for a couple of days and if it still won't start then the battery is bad no matter what Autozone says. On the other hand if the car starts then the theory I stated above is correct and you will need to figure out what is causing the drain on the battery.
Old Oct 7, 2008 | 10:42 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: lost
the only thing i can think of is something being left on in the car or something not wired right and drawing current thus running the battery down over a couple of days
Old Oct 8, 2008 | 10:13 AM
Re: lost
alright guys thx for the help i'm gonna check it out tonight
Old Oct 8, 2008 | 03:10 PM
Re: lost
and i forgot to mention the battery is about a month new so im thinking theres a short somewhere causing my battery to drain
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
