P/N switch Wiring for T5
Old Oct 18, 2008 | 10:54 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just converted my car from an automatic to a 5 speed. I know that from the old park neutral switch, that the yellow and purple wires go to the clutch safety switch and that the blue and green ones are for the reverse light, but what do I do with the two other wires?
Old Oct 18, 2008 | 11:44 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: P/N switch Wiring for T5
I think they are for the rear hatch button so you can only open it in park.
Old Oct 18, 2008 | 04:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The only wiring you need to modify for the NSS is for the reverse lamps. You will have a connector already under the dash for the clutch switch, although you may need to modify the wiring for the connector you have with your clutch switch.
You can leave the connector under the console and merely tuck it out of the way.
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
