funny fuse question
Old Nov 7, 2008 | 01:43 AM
Kandied91z's Avatar
funny fuse question
have a 10 amp(red) for my guage cluster that pops when i turn the ignition key and start the car.
controls guage cluster, interior lights, etc.
but, when i start the car and put the fuse in all is fine.
any suggestions of where to start?
Old Nov 20, 2008 | 12:12 AM
Kandied91z's Avatar
Re: funny fuse question
nobody? hmm.
Old Nov 20, 2008 | 09:24 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I would suspect a burnt out lightbulb in one of the warning lights. It would logically explain it: you turn the key, warning lights come on and blow the fuse (if there is a short in a bulb). Then once the engine is started, warning lights are off, so the fuse won't blow then.
I'd pull the instrument cluster and check all warning lights bulbs with an ohmmeter (or with a battery).
Hope this helps.
Lou
Old Nov 20, 2008 | 02:17 PM
Kandied91z's Avatar
that's a start, thank you.
Old Nov 20, 2008 | 02:34 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
When Is it popping exactly with the ignition on or when you actually crank the engine?
Old Nov 20, 2008 | 11:47 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Im interested in this as I am having this exact problem in my iroc, although I haven't tried putting in the fuse once the car is cranked. I am going to check my bulbs to make sure that I don't have an extra bulb in their. Their were a few dead/empty bulb spots on mine if I remember correctly.
Old Nov 21, 2008 | 11:03 PM
Kandied91z's Avatar
when i crank the engine.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Moore89
Aug 24, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
