idiot lights
Old Nov 13, 2008 | 01:45 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
idiot lights
I have a non-ecm, carbed, 350, 4spd, Camaro
I have both "choke" and "upshift" lights and I'd like to hook them up, just for fun. I do have an electronic choke carburetor (EDL-1406)
I was thinking of hooking up the upshift light like the ones on those stand alone tachs but don't know where to start
any help?
Old Nov 14, 2008 | 01:24 PM
C.M.Jones's Avatar
Re: idiot lights
I lied LOL I don't have an upshift light (not yet) must've saw it on one in the junkyard but I do have a choke light I'd like to see working
Old Nov 15, 2008 | 10:28 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: idiot lights
The choke light light up if/when the charging system fails.
Old Nov 15, 2008 | 12:40 PM
kcb37's Avatar
Re: idiot lights
You can buy an aftermarket shift light, unless you want it like factory.
Aftermarket, would come on at a set rpm, factory varies, and I am not sure, but I think it's info, comes from, I would assume the computer, thur the tps, vss, and map sensors.
Old Nov 17, 2008 | 10:01 PM
C.M.Jones's Avatar
Re: idiot lights
Im wondering if there is a way to hookup the light to the factory tach like ones on a aftermaket. I know stock goes through the ECM but I don't want it stock anyway because I want it for performance, not economy
so why would GM make a light that says "choke" as a battery light? thats silly unless there trying to say the battey is choking because its not getting enough power? LOL
so could you hook it up to the choke? that be cool then you know on cold days when your cars ready to go
Old Nov 19, 2008 | 02:14 PM
Re: idiot lights
The stock choke light doesn't operate through the ECM. My 84 Z28 didn't have an ECM.
GM, Ford, and Chrysler (among others) have used the choke indicator on carbed cars for years to alert the operator of a charging system problem. Long before the ECM became an integral part of the vehicle.
No reason you couldn't hook up the choke light to act as a shift light, provided you used an ignition box of some kind (MSD or other) to trigger it. You'll just have to trace some wiring and figure out how.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
