Fog Light Help!
Old Dec 12, 2008 | 11:36 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Fog Light Help!
I bought Auxiliary lights from auto zone for $17; they basically look just the same as the stock fog lights to the car; now my car doesn't have the fog lights when i got it. The directions ask me to hood up a cord to the fuse box.
My question is where does this cord go in the fuse box? Also I have the switch that would come in the dash side where the light switch would be on the car. Now instead of using that switch from the package i got i could use the one that i got that comes with the car as well? If anyone could help me asap that would be great! thanks!!!
~mike
Old Dec 12, 2008 | 11:52 AM
Stephen's Avatar
Car: 87 GTA
Re: Fog Light Help!
What do the INSTRUCTIONS say? Constant power? Key on power?
Hard for anyone here to say, what that wire even is, without knowing how it is set up.
Old Dec 12, 2008 | 01:14 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Fog Light Help!
http://www.pilotautomotive.com/Produ...roductID=27284
this is what I got
You either get to chose; there is a switch for "key power" when you press it down, or you could directly hook up to the battery it says. I'd rather have through the fuse box just in case. I just like to know where mine would be located to hook up since i think this is an option to access in fuse box because the camaro was given the option to have fog lights?
!!!EDIT!!!
I feel like an idiot; nevermind i figured it out. the kit came with a black block that is the fuse.. :\ silly me, im sorry. i cant wait to finish i just need to buy more wire and solder some and then heatshrink and finish this up and then ill have fog lights On the switch though which power in and ground?
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
