no spark? new dist. and coil
Old Dec 22, 2008 | 02:51 PM
arodgers07's Avatar
Car: 85 IROC-Z
i have an 85 iroc that recently caught on fire in the rear of the engine bay and my distributor and wire harness were melted as one. i pulled the wire harness and repaired it and i replaced the stock distributor with a pertronix flame thrower with a vacum advance and a pertronix coil. i got the distributor and coil used so it didnt come with instructions. i have it hooked up to what i thought was right but still not getting any spark. im drawing a mind blank. im pretty sure that ive got the the coil hooked up wrong. someone please help i hate seeing my car down
Old Dec 22, 2008 | 03:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THEN MAKE THE BODY SPARKLE
If you’re using the canister coil the check for a reversal of the B+ and grounding leads.
Because you bot it used you should test it out of the car before proceeding.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Dec 22, 2008 | 04:20 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: no spark? new dist. and coil
wires melt, fuses blow.Check your power supply
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
