newb needs some help
Old Dec 27, 2008 | 11:12 PM
grims846's Avatar
well first of all let me say this is the first car i bought and also one ive wanted since i started walking. but with that being said ive ran into a few problems over the last day.
it started with my trunk not pulling down then i relized the head rest lamb wasnt coming on. now i noticed the power locks arnt working. keep in mind ive also had problems with my head lights coming off and on randomly. and when i say turning off i mean the interrior lights and brights indicator work just not the head lights.
any idea if this may be caused by a fuse or somthing small?
help would be greatly appreciated
Old Dec 28, 2008 | 03:45 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: newb needs some help
Sounds like a bunch of problems. Has the car been previously butchered? Start by checking the battery ground for the headlights. Pull down motors commonly go bad.
Old Dec 28, 2008 | 09:55 PM
91blue_phoenix's Avatar
Car: 2000 Ford Focus
Engine: 2.0L CVH/SPI I-4
Transmission: IB5
Axle/Gears: stock
Check grounds for the headlights. That could be the issue. It could also be the contacts inside the high/ low beam switch.
The hatch pull down motor goes bad, and is probably the issue with yours. Ya need a new one. Simple as that. Or you could just adjust it down and use it like a regular trunk latch, but I don't reccomend this.
bluechevy194
Mar 19, 2006 07:59 PM
BOSS 357
Nov 2, 2005 11:04 AM
IROC-Turbo
Carburetors
Apr 6, 2005 05:31 PM
ajbutowicz
Nov 13, 2004 02:46 AM
okfoz
Jun 13, 2001 10:44 PM
