Where should i tap autometers to
Old Feb 7, 2009 | 02:52 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i have a FP gauge and afr gauge and a tach which wire inside should i tap into to power these because im running them striaght to the battery and my battery gets drained if i dont run it for a couple of days so if anyone could help me out that would be great
p.s. which wire and what color is it and where should i hook it up to. plus where should i run the lighting wire for the gauges inside?
Old Feb 7, 2009 | 02:57 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Where should i tap autometers to
When i wired in my tranny temp gauge i just used the wiring off my stereo cause that covered all i needed. You want the switched 12v (i cant remember what color that is..aftermarket stereos have that as yellow i believe), ground (black) and illumination. All those shall work for your gauge. Ive had mine in for awhile now and no problems. Some people im sure will cringe at the thought of wiring it to the stereo but its a gauge. Its not using that much juice to work.
Old Feb 7, 2009 | 03:39 PM
Car: 1991 Trans Am
Axle/Gears: Stock
so you saying i can put my power wire (red for gauges) to the yellow wire for radio (power when key is turned) and it should all work then if so thanks alot for your help i have something to do tomorrow if its good its just the 2 gauges so i should be fine.
Old Feb 7, 2009 | 06:12 PM
subroc's Avatar
Engine: 355 TPI
Yup you need to plug your gauge power wire into a switched 12v source. Dont quote me on the color of the wire out the back of the stereo. I have an aftermarket in my car and i believe that universally they have yellow as their switched 12v. As far as what color the factory wire that it plugs into is...that i havent a clue. You can always verify with a voltmeter though.
Hotrodboba400
Dec 10, 2019 07:07 PM
Fred SS
Oct 12, 2015 11:27 AM
90formulaVortec
Sep 8, 2015 12:42 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
