Light buzzer
Old Feb 15, 2009 | 02:07 PM
mikedingus's Avatar
Light buzzer
I have an 89 RS. After I have started the engine and switch the lights on the dam buzzer comes on. Is there any obvious reason why the buzzer is coming on.
Old Feb 16, 2009 | 02:07 AM
ffemtm70's Avatar
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
Re: Light buzzer
I have the same problem....couldn't figure it out so I just pulled the dang buzzer thing out.
Old Feb 16, 2009 | 12:06 PM
NINĹ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The audible alarm alerts you when the seat belt is not fastened or when your door morphs into a jar.
If it’s staying on when it’s not supposed to one of the actuating switches might not be opening.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 16, 2009 | 01:18 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Light buzzer
Nina is right, it seems like door chime module isn't getting all the right inputs.
In this specific case, I'd bet that it's not getting full 12V on the pink ignition wire which make it think (if hardware can have thoughts ) that you turned your headlights on without turning the key on.
I'd try wiggling the door chime module in its socket, maybe even pulling it out and cleaning the contact blades. If that doesn't help, it's time to start measuring wires.
Lou
Old Feb 16, 2009 | 01:58 PM
mikedingus's Avatar
Re: Light buzzer
Fixing to go look over everything that was suggested.
Old Feb 16, 2009 | 02:21 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Light buzzer
Is it the headlights ON warning or the door open/key in the ignition warning going off?
I'm assuming the warning turns on only when the headlights are switched on?
If it's the headlights ON warning, try turning the dimmer full dim. The warning should turn off. If this is the case, I'd look for a bad headlight switch.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
