help please, does 86 roc have computer
Old Feb 16, 2009 | 09:51 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
i have an 86 iroc that came with a 305 carb. i now have a slighty modified 350 and i'm having major issues.
my car runs like a champ except at 5000 rpm's. once i reach that rpm the car will start skipping and popping.
to the best of my knowledge the computer shouldnt be hooked up, but the car redlines at 5000 rpms and that is where my car starts skipping and popping.
could the computer be giving me a problem?
Old Feb 16, 2009 | 11:50 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Some third gens are equipped with a vehicle speed limiter which prevents attaining top speed.
However, most of them are were the high winding 305 TBI’s.
Z28’s and other TPI’s are not equipped with a limiter.
The limiter should function in top gear, not neutral.
A well tuned engine will sound beautiful at 5000 RPM.
It sounds like you have an ignition problem.
An oscilloscope would tell you allot in this case.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 16, 2009 | 03:31 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
Re: help please, does 86 roc have computer
thanks for the response.
ive had this problem for years and i cant figure it out. i have new plugs, wires, cap, button, distributor, heads, intake, hell the engine only has 6 thousand on it. ive changed the carb, cam and lifters. i'm really out of ideas. i'll start checking around for a oscilloscope.
i even changed out the module in the distributor yesterday thinking it could be going bad! WRONG!!!
Old Feb 16, 2009 | 07:27 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
weak valve springs can cause that problem-my '69
camaro did that exact thing,right at 5000 rpm-springs
had 140,000 mi on them.
Old Feb 17, 2009 | 07:24 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
yeah i thought about the springs too. i have had two different sets of heads, both fresh, same results. the second set of heads, i had the springs installed to match my cam. that doesnt mean the guy at the machine installed the stiffer springs i paid for though.
i've also tried a different coil.
let's say for shiz and giggles that my car has a rev limiter. if i ran a straight 12 volts to my coil, for test only, would that bypass my limiter?
Old Feb 17, 2009 | 09:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
What about fuel delivery?-stock fuel pump would not
keep up at high rpm on my'82,car did not pop though,
would just start to buck and surge-fixed the problem
with an electric fuel pump that i had on hand.
The popping sounds like an ignition problem,but you
have subbed out all ignition parts with no improvement!
could try running12 v straight to the coil just to make
sure it is getting full voltage.There is no rev limiter on
thirdgen ignitions,ECM only controls the spark advance.
good luck!
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
