No lights! What's wrong?!
Old Feb 19, 2009 | 10:40 AM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
None of the lights work like check engine, security, etc, not even during start up. The only thing that lights up is the E-brake. What could be the cause of this?
The odometer and trip odometer are shot as well.
Old Feb 19, 2009 | 11:51 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
First check if the potentiometer on the headlight switch is getting power in and out.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 19, 2009 | 12:06 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: No lights! What's wrong?!
I think he meant the warning indicators on the dash.
My first thought was "check your GAUGES fuse in the fuse panel" but since the E-brake light works fine (powered from the same fuse), I'd suspect the bulbs. Often, previous owners pull out lights to hide a problem with the car when they're selling it. It's common practice. So I'd pull the cluster and check the bulbs. While you're at it, look at the connectors on the back of the cluster to see whether there is any damage. Maybe the printed circuit board is folded?
Hope this helps.
Lou
Ghettobird52
Jul 5, 2024 11:18 PM
evilstuie
Jan 9, 2020 08:29 PM
Jae992
Aug 27, 2015 09:07 AM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
