Fuel injectors firing
Old Feb 21, 2009 | 03:39 PM
mfaust's Avatar
Car: 88' Trans-AM WS6
Could someone explain how the fuel injectors are fired?
Apparently there are only 2 wires coming from my ecu D15 and D16 which switch to ground firing 4 cylinders each time.
the other wire is connected to 12v all the time.
Is this correct?
Old Feb 22, 2009 | 10:21 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuel injectors firing
The injectors have power through fuses and are grounded by the ECM, all 8 at once (it's called "batch fire"). They are fired on EVERY revolution, so twice per firing cycle.
Hope this helps.
Lou
Old Feb 22, 2009 | 10:29 AM
mfaust's Avatar
yeah, I think I got it. Im trying to read the rpm's and Im reading the pulses just might have to adjust the multiplier.
1000 pulses/min should be 1000 rpm
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
