C207 connector doesn't match??
Old Feb 25, 2009 | 04:53 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
I am doing a swap on my 87 Camaro..It was originally an lg4 engine and is now going to be a TPI engine...
I am in the middle of the re-wiring....
On my C-207 connector I have this colors:
A - BRN
B - NOT USED (INJECTORS)
C - WHT/GRN
D - BLK/ORG
E - WHT/BLK
F - PNK/BLK
G - NOT USED (INJECTORS)
H - TAN/BLK
R - BRN
P - PPL
N - ORG/BLK
M - BLK/WHITE
L - BRN
K - BRN
J - PPL/WHITE
When you look at a diagram of the C207 connector in 1987 some of the wiring doesn't match...Can anyone tell me what is what here??
Here is the C207 connector:
Old Feb 25, 2009 | 04:57 PM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
Re: C207 connector doesn't match??
which tuned port are you installing? is it an 1987? Speed density or MAF ? I also have an 87 camaro im swapping to a 350. I looks like a huge wiring nightmare.
Old Feb 25, 2009 | 04:58 PM
I am installing a MAF system...The TPI wiring harness comes from a 1988 Camaro with 305 TPI engine...
Old Feb 26, 2009 | 06:15 PM
Car: 1987 LT Camaro
Axle/Gears: 4.11
The problem you will most likely incounter is that on the 87 the wiper motor and washer fluid pump are on the engine wiring harness. on the 88 they changed. the washer pump is inside the washer resevoir. also the wiring for these components on a 1988 are located in the headlight harness. just something to think about.
Frozer!!!
Jan 19, 2024 04:55 PM
GTAman
Mar 15, 2019 11:40 AM
deracer
Apr 11, 2016 12:04 AM
hectre13
Sep 8, 2015 03:38 PM
mizz0313
Aug 12, 2015 06:45 AM
