After market speedo and 700r4
Old Mar 12, 2009 | 08:40 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
Heres a little backround... 91 formula with 700r4 i did a motor swap and did away with all the fuel injected computer controlled things. the carb is now all carb setup. problem is speedo doesn't work now. I was thinking of maybe some cheap autometer gauges, but how would all that work with a 700r4 that was once computer controlled. basically what kind of gauge do i need and is there a special way to connect it now?
Old Mar 13, 2009 | 11:19 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
If you removed the electronics that ran your electronic speedometer you can convert to a mechanical speedometer which will be driven by an electronic to mechanical adaptor.
You do not have to disassemble the tranny to install the adaptor.
Then you can get the Autometer speedometer you want.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights or in the daytime!
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
6998poncho
Sep 25, 2015 02:56 PM
