heads lights starting flashing
Old Mar 13, 2009 | 11:57 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
whats up guys.
i took my 86 iroc for a run last night and on my way home my head lights started flashing. i didnt pay attention to the dash lights or anything else because i was too concerned with my headlights. anyways, they blinked on/off about 6 times so, i turned them to bright and back to dime and it didnt happen again. if you've had this problem or if you have any suggestions please post them.
i need to locate this problem asap because i'm taking it to the drag strip next friday and thats a 2 hour drive one way. thats a long drive in the dark!
thanks guys!
Old Mar 13, 2009 | 12:05 PM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Re: heads lights starting flashing
sounds like one of the light switches is getting hot/ going bad. my buddy has a 73' ford f100 and his did the same thing. he changed the dimmer switch and the on/off switch and they haven't done it since.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
