Alarm system wiring help!
Old Mar 19, 2009 | 02:37 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I am installing a alarm system on my Camaro and it is asking to splice the turn signal wires. How can I identify these underneath the dash???
Also I am putting it on a convertible. My kit has an optional trunk release option. But my button releases the tonneau cover not the trunk. If I buy a normal trunk release can I wire it to work?
Old Mar 19, 2009 | 04:11 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Alarm system wiring help!
is it asking you for turn signal wire or for the parking light wire?
all of the alarms i have installed tie into the parking light wire so they can flash the lights if the alarm goes off and when you arm/disarm. the best place to get the parking lights is right off of the switch or in the driver kick panel.
no idea on the trunk actuator, never worked on a 3rd gen vert.
Old Mar 20, 2009 | 02:13 PM
JTNKTZ's Avatar
Engine: 355/350
No it is asking for both turn signal wires because it shows one wire to the left signals and one to the right.
Old Mar 20, 2009 | 02:17 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
You will need a test light to check for sure, I believe the colors are green and yellow for left and right turn. These wires will be on the steering column and in the drivers side kick panel. The Parking light wire is dark brown.
midge54
Dec 27, 2019 04:14 PM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
