Wheres my tach wire?
Old Apr 25, 2009 | 08:21 PM
GIJason91's Avatar
Car: 1991 Camaro RS
Engine: 5.7 350 TBI
Transmission: M5
i have a 1987 camaro iroc z28 350 tpi and i'm wiring in a MSD street fighter ignition box(same wiring as 6al msd box) this box has a gray wire to go to the tach, which wire is my tach wire on the back of my gauge cluster? originally the tach used the white wire comming from the ignition coil and that is re routed to the box i need to kow which wire comming from the back of my cluster i need to splice it into. thanks!
Old May 21, 2012 | 02:46 PM
PUNISH3R's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
Re: Wheres my tach wire?
GIJason91 - Hey did you figure out were the Gray "Tach Wire" from the MSD box goes?
Old May 23, 2012 | 06:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You only use one tacho hookup ;
the tacho wire to the box you are currently using or the tacho wire to the grey ; not both
http://static.summitracing.com/globa...5_frm29772.pdf
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
