if you know anything about fuses and wiring!
Old May 13, 2009 | 11:29 AM
92FormulaBird's Avatar
so when i pulled into the parking lot at work i tried rolling up my windows but they would roll up..afterI checked out the fuses i swapped around the metal fuses and little by little they rolled up...well i went and bought new fuses and they worked until i turned the car on...then the radio cut off and the windows wouldnt budge. so i switched them around rolled them up left it alone...next day i go outside and they roll down everythings fine until i turn the car on..and i notice smoke coming out of the hole were the e-brake is..go to pull the fuse and it was so hot it burned me! now i havent driven my car in 4 days and its killing me i have other posts but no ones responding..minus the check fuses (yes there the right size) and check the cigg lighter (which was clear of any metal) btw after the smoke my power door locks wouldnt work either! someone please help me!!!!
Old May 13, 2009 | 01:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BROKEN WINDOW BUT THE WINDOW AINT BROKEN
Did someone alter your fuse block?
You’re not supposed to have window fuses.
It should be a 30A circuit breaker.
Make sure/return the block to stock.
Post your findings.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
GTAman
Mar 15, 2019 11:40 AM
stalkier
Dec 6, 2015 11:25 PM
