Interior lights and switchs out of comission
Car: '88 Iroc-Z
I was trying to hook up my fan which was plugged into the fuse box and when I took it out and put it back in it sparked and the fuse light, hatch switch, side mirror switch, and interior overhead lights wont work. Anyone got any suggestions as to what this would be?
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Interior lights and switchs out of comission
Those circuits are powered by the ACC fuse. Check it, it is likely that it's blown.
Lou
Lou
Car: '88 Iroc-Z
Which is the ACC fuse? and we tested the wire to the hatch next to the switch and there was no power so we disconnected it and hooked it to the stereo power wire and it worked. Would that still be the fuse or wiring problems? the lettering is rubber off my fuse box so i cant see which is the ACC
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check post #18 and 19 in the following link:
https://www.thirdgen.org/forums/inte...r-install.html
JamesC
JamesC
Car: '88 Iroc-Z
Thanks bro, I checked up on it and it actually was blown fuses for both of my problems, I feel like an idiot for not checkin that, hah. Now when i get my speedo workin ill be good to go. Thanks again for the help
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
