Fan wire to IGN in fuse panel?
Old Jun 17, 2009 | 11:28 AM
Chuck's Avatar
Is it ok to run a wire from a switch to one
of the IGN connections in the fuse panel?
Old Jun 17, 2009 | 12:22 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fan wire to IGN in fuse panel?
Nope, it's not ok.
That would be overloading the wiring for the ignition switch, creating a potential fire hazard.
The right way to do it is to fix the fan circuit.
Troubleshooting article here: http://www.austinthirdgen.org/index.php?pid=36
Hope this helps.
Lou
Old Jun 17, 2009 | 01:37 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Electric fans can draw 15-20 amps, that's too much for direct power from the ignition switch. You could run a wire from there to a relay under the hood. Put a 3A fuse in the wire near the fuse box end.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Street Lethal
Aug 14, 2015 08:25 PM
