power windows
Old Jun 17, 2009 | 03:16 PM
deadly's Avatar
power windows
my power windows worked sometimes but now the dont work at all.. I was told it was the switch, but if it isnt the switches what other problem could it be?? did anybody ever experience this problem in there 1983 trans-am..
Old Jun 17, 2009 | 04:17 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: power windows
Pull the switches off the connectors. Grab a test light or voltmeter and test for power on the pink wire. If you don't have power, check the ACC circuit breaker.
If you do have power, I'd measure the resistance of the window motors on the connector. Set the DMM to resistance (if no autoranging, set it to 10 or 20 ohms or so) and put the test leads on the dark blue wire and the brown wire (or light blue and tan for the passenger side motor). You should see very small resistance (can't remember exactly, probably around 1 ohm or maybe less). If no resistance, the motors or the wiring is bad.
Hope this helps.
Lou
P.S.: Diagram here: http://www.austinthirdgen.org/mkport...er_windows.jpg
Old Jun 17, 2009 | 11:22 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Re: power windows
Mine are super slow, but never not work.
What he said. Bust out the Ohmmeter.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
