1987 IROC temp gauge not working
Old Jun 17, 2009 | 08:48 PM
Kip Page's Avatar
can you help me out...is it a bad gauge or bad temps sensor...etc..???? help
Old Jun 18, 2009 | 09:25 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 1987 IROC temp gauge not working
Elaborate on "not working". Does it constantly show cold? Or constantly hot? Or sits in the middle flipping left and right to the beat of the music?
You can test this simple circuit by unplugging the sensor wire (dark green) on the driver side (sensor is in the head between first two spark plugs). The gauge should read cold.
Then put that wire on a good ground (block, bolt etc) and the gauge should read hot.
All that with the key on, of course.
If the gauge behaves correctly during the test, it's good and the sensor is likely the culprit.
Hope this helps.
Lou
Old Jun 22, 2009 | 09:25 AM
Kip Page's Avatar
the gauge is pegged to beyond the hottest mark whether is the key is on or not
Old Jun 22, 2009 | 10:33 AM
BigBadLou's Avatar
Engine: TPI
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
