Vortec PCM help
Old Jun 23, 2009 | 09:49 PM
bronc3buster84's Avatar
Car: 2001 GMC Jimmy
Transmission: Nv3500 5 speed
Axle/Gears: Dana 44's f&r, 4.30 gears
Vortec PCM help
Ok all heres my problem. I have a tpi setup running the vortec pcm. I have power and ground to the pcm. The thing is i have no signal to the fuel pump relay or the check engine light. I can ground both and they work. Also when the coil is hooked up the ign. control module gets hot and the coil shoots sparks. I tried a different coil and module. I also have tried a different pcm. I built the wiring harness from scratch. Also when touching the pcm housing with a test light it lights up. Dont know if its suppose to do that or not. Sorry for the novel, but i need to get this figured out. Thanks
Old Jun 24, 2009 | 07:37 PM
Car: 2001 GMC Jimmy
Re: Vortec PCM help
Ok I figured out my problem. Just had 2 grounds in the wrong spot.
69GTOby
Apr 18, 2016 02:34 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
