easy wiring question please help
Old Jun 27, 2009 | 04:37 PM
hotcamaromess's Avatar
Where does the negative terminal connect to on the opposite side of the battery? If I had to guess it looks like on one of the alternator mounting bolts, but I took this engine apart a year ago and forget. 305 carbed stock, thnks
Old Jun 27, 2009 | 05:14 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: easy wiring question please help
the negative lead from battery normally is a 2 wire . the large one goes the engine , the front of pass. side head . the small one to the chassis , good metal part of the engine bay . the negative lead is ground . no elect. stuff will work with a good ground . good luck .
Old Jun 29, 2009 | 09:58 PM
whatamidoing's Avatar
Car: 1986 camaro
Engine: 92 v8 5.7l
Transmission: stock
Axle/Gears: stock
hey i just got a 1986 camaro with a 92 v8 5.7 liter engine in it . the car was running really crappy so i had to change firing order on the car it was running alot better.. but still wasnt right about a week later i discovred the smog silinoid was disconnected from the terminal where it goes into the top of the engine also the electric was not pluged into the conponent. i did some research and found out the correct way to hook it up .. i started and drove the car about 5 blocks car seamed to be running better then ever smooth and more power . after i turned the car off and tryed to start it up the next day .. car does not start .. as u hold the exnition and pump the gas the engine gets slowly to full running speed as if its running and when i let go of the exnition it turnes off as quick as i let go ?? i also tryed removing the smog silinoid back to how i org found it still same story any suggestions ?? thanks
Jorlain
Aug 24, 2022 05:11 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
