oil sensor
Old Jul 4, 2009 | 05:39 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
oil sensor
ok ive got an 86 camaro with the 305 FI.... been having funky oil pressure readings so im going to change both sensors/switches..... my question is... i can easily find the sender on the right hand side of the pic... but the one on the left?... not a freakin clue... does anyone have the part number for this one... remember it is NOT the same as the later 91-92 ish models.... oh also the only number i found after searching is D1843.... which only shows applicable to the 4 cyl models....
Old Jul 4, 2009 | 06:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: oil sensor
Only the one on the right controls your gauge. The one on the left powers the fuel pump if the relay fails.
Old Jul 4, 2009 | 06:42 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: oil sensor
well ive chnged the bellshaped one already but my pressure is still jumpy... i was told that the other sensor also CAN be related to the issue
Old Jul 4, 2009 | 08:33 PM
jv9999's Avatar
Engine: 5.7L/350
Re: oil sensor
You were misinformed. If your voltage is stable, it's probably time to put a mechanical gauge on it and see if it's telling you the truth.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
