NEED HELP WITH WIRE TUCK / HIDE
Car: 92 CaMaRo RS
Engine: CARBED 350 5.7
i have a 92 camaro rs with a 5.7 350 swap and the tpi has been changed to a carb. need some tips on how to do a wire tuck. google didnt help me much.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: NEED HELP WITH WIRE TUCK / HIDE
just use some electrical tile if you don't want to cut and shorten your wires.
Car: 92 CaMaRo RS
electrical tile?! when people do this do they normally cut and shorten wires? i thought you just tucked them in the fenders or in the frame some how. when i bought my car the carb conversion was already done. i could use some help as far as what im using and what im not. is there a write up on this? i wasnt able to find one. thanks for the help.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
You can put em in wire looms or cut'em......post up pics....they might help
Car: 92 CaMaRo RS
this is my current set up. 350 with carb conversion. please dont judge me based on how dirty my engine is. i plan on cleaning it up within the next couple days. if i remove the harness will my cruise control, ac, gauges, fuel pump, and ignition will still work properly? just triple checking before i yank it out tomorrow. i know i will need to rig up something for my tc. i already have something in the works. thanks for the help.
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Before you do anything, go look in the carb section. Read up, look at pictures, ask questions, and do some more research.and learn from other people build/mess ups.
Car: 89 IROC-Z
