Name that thing!
Old Jul 14, 2009 | 11:03 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Name that thing!
Not sure how to do a search for this....
1992 RS 305 TBI Driver side firewall between brake booster and fender. Small bracket holds relays for fan and fuel pump. On the front of the bracket, there is a flat connector that plugs into a flat THING that mounts on the front of the relay bracket.
In the pic, it's the THING that has a sticker that reads "BLH"
Name that THING!
Old Jul 14, 2009 | 10:19 PM
AmpegVT22's Avatar
Car: 92 RS
Axle/Gears: whatever the stock gears are
Re: Name that thing!
I may be wrong but I think that is the hook up for your wiper motor.
Old Jul 14, 2009 | 11:29 PM
white rider's Avatar
That part is the electronic spark control module. Only used on tbi engines. most auto part stores carry them in stock.
Old Jul 15, 2009 | 10:34 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
White rider is right on the money, it's the ESC module.
If you are buying a new one, make sure you get the one for the 305 engine because each engine displacement uses a different ESC module.
Lou
Old Jul 16, 2009 | 06:10 AM
Car: 1992 RS
Engine: Carbed 350
Thanks guys! With the carb, I don't need that - out it goes!
Old Jul 16, 2009 | 11:02 AM
AlanMcGee's Avatar
I came here to post this exact question!
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
