Esc decisions?
Old Jul 21, 2009 | 07:28 PM
86irocz400's Avatar
Esc decisions?
I have a 86 irocz that stock had a 305 and i installed a 400. I have it tuned to run pretty good but today when i was reading today i found out that if you do a 305 to 350 swap u need to change the esc and knock sensor to one designed for a 350 car. But my problem is i have a 400 so what should i do in this situation? I cant seem to find any info on a 400 swap as far as esc and knock sensor. I believe i would be better off upgrading to the 350 parts vs keeping the 305 parts. I am just wondering what the 383 and 400 guys are doing to make it work.
Old Aug 21, 2009 | 09:14 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: Esc decisions?
I'm wondering the same thing 400 block with code 43 all day long. Wrong sensor?
If so which is the right one?
Old Aug 21, 2009 | 10:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Esc decisions?
I believe the 400 is pre-computerized stuff - thus there is no knock sensor or ecm available. I would think 350 stuff would be better, but I'm no expert. TBI or TPI? Might try in one of those boards.
ZZ3Astro
Aug 13, 2019 12:57 AM
L98GTA87
Oct 19, 2015 10:43 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
RGB2015
Sep 20, 2015 09:26 PM
RyanJB
Sep 2, 2015 01:27 PM
