headlights
Old Jul 23, 2009 | 10:22 PM
inukiller5's Avatar
Car: 1989 Iroc Z
Transmission: turbo 350, 2500 stall, b&m hammer
Axle/Gears: 4.11 posi
headlights
ok.. So i just got a 1989 Iroc camaro... now when i cut on the high beams all the lights go out... i checked the connection and everythings good... the low beams work fine... can i get some help
Old Jul 24, 2009 | 12:42 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: headlights
The question is: are you getting any voltage at the lights with high-beams on? I'd grab a test light and and probe the terminals.
If no voltage, I'd check out the dimmer switch next. It is on the left side of the steering column, under the dash, above the brake pedal assembly.
Wire colors are in this diagram: http://www.austinthirdgen.org/mkport...headlights.jpg
Hope this helps.
Lou
Old Jul 28, 2009 | 10:49 AM
inukiller5's Avatar
Car: 1989 Iroc Z
Re: headlights
ok i replaced the headlight dimmer switch... now when i switch to high beams... only the passenger side lights come on. the high&low on the passenger side it on... but no lights on the driver side is on.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
