STILL NEED HELP!!!!
Old Aug 21, 2009 | 12:57 PM
89tpirocamaro's Avatar
Car: 89 camaro iroc z28
Engine: 355 carbed
Transmission: t-5 speed
Axle/Gears: 2.73 posi drum rear
STILL NEED HELP!!!!
my 89 305tpi camaro has a problem. when i first start it up( motor is cold) it drives and runs fine. when i shut the car off and go to start it again (motor is warm) it wont start. its at the shop and they tested the wires that cap on to the fuel injectors and when hot the light is very dim compared to very bright when cold. they just put in a new distributor, ignition coil so its not an ignition problem...... starting to think that the problem is in the harness because my car sat and mice made a home inside the dash.....someone please give me some answers so i drive my car
Old Aug 21, 2009 | 01:21 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Re: STILL NEED HELP!!!!
sound like an interesting one, the only thing that i can think of doing is to trace all the wires back to your ecm and see if you have a bad ground or a bad wires along the lines
Old Aug 31, 2009 | 07:50 AM
Burbo's Avatar
I have the same problem, 91 Z28 w 1987 L98 350 TPI 400 R4, gets hot, shut it down and then it won't start till it cools, Some suggest that i move my coil because they think it's getting to hot (temp ~180 - 200 range) Any one tell me where a Horn relay is and i need to replace turn signal switch
Thanks for your help very one
Burbo
