Headlights won't go down
Old Aug 31, 2009 | 05:16 PM
jagmanofsteel's Avatar
Car: 88 Trans Am GTA
Transmission: Borg Warner WCT-5
Axle/Gears: 3.45
88 trans am. Headlights come up with the headlight switch but do not do down I have to turn the ***** to get them back down. The headlight motors do not turn when headlight switch is turned off. HELP!!
Old Aug 31, 2009 | 05:31 PM
Stephen's Avatar
Car: 87 GTA
Re: Headlights won't go down
Heck the Headlight Control Module on the drivers side firewall. The "down" side might have a bad contact inside.
When they won't go down, leave the switch off & try tapping/hitting on it. Mine used to go down but not up & a slight hit would make them come up. Or driving would cause enough shake to achieve the same thing. I just replaced the whole unit, since I had another one.
Old Aug 31, 2009 | 09:33 PM
Axle/Gears: 3.45
Thanks Stephen. Yeah I got a buddy with the same problem and he has to tap it to make it work. I found the problem like two minutes after I made the post. It was the white wire on the left side of the control module. It is suposed to send power to the unit when the lights are turned off. And it doesn't. Tomorrow I will take the headlight switch out and see if it is attached. Thanks again Stephen.
Old Aug 31, 2009 | 09:41 PM
Stephen's Avatar
Car: 87 GTA
You can open it up (4 small screws, iirc) and resolder that connection, if that needs to be redone.
jrdturbo
Mar 31, 2016 02:58 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
meeklay812
Oct 1, 2015 03:46 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
Eric-86sc
Sep 28, 2015 11:37 AM
