which wire goes to tach?
Old Sep 6, 2009 | 09:49 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
doin a carb swap on 91 camaro, i did have a tpi setup with external coil. now i have a hei distributor, so which wire do i need to connect to distributor for tach signal? was thinking white wire from external coil connection?? thanks for any input
Old Sep 6, 2009 | 09:53 PM
Pocket's Avatar
Car: 91 Trans Am
Re: which wire goes to tach?
On the coil there are two connectors. A black one and a gray one
The gray one is ran directly to the C100 and is the main IGN power to the engine harness. The white wire with it goes directly to the tach
Old Sep 7, 2009 | 02:42 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
thanks a lot
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
