Fog lights
Old Sep 7, 2009 | 06:25 PM
Goldenbullet44's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 smallblock aftermarket cam
Transmission: Borg warner T-5
Fog lights
I cannot get my fog lights to work i have checked the fuses and such any ideas?
Old Sep 7, 2009 | 06:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fog lights
Bad relay?
JamesC
Old Sep 7, 2009 | 06:54 PM
Re: Fog lights
Were would the relay be located? could it be a bad ground aswell maybe? i wouldnt know were to look =/
Old Sep 7, 2009 | 07:48 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Fog lights
Do you hae a meter and know how to use it. IF not they have real cheap ones at walmart for under $20. WIht that you can check the grounds and also see if you have voltage at different locations.
Old Sep 8, 2009 | 07:04 AM
JamesC's Avatar
Re: Fog lights
On an IROC, the fog light relay should be by the fusebox, a plastic cube with a standard relay connector. You may find something the following link that would be more helpful:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
