low beams, hatch motor, interior lights wont work
Old Sep 18, 2009 | 09:10 PM
feydeykin's Avatar
Car: 91 Chevy Camaro 305 TPI manual
Hi, I have a 91 Camaro 305 TPI, was working on it yesterday installing a speaker on the driver side, I used the time to relocate some cables under the dash that were too close to the pedals when I noticed that the low beams, interior lights, power locks position lights wont work. Thinking it was a fuse I checked the fuse that usually takes care of that circuit and it was ok. All fuses are ok. Tested all of them with a fuse tester and good. Took the fuse panel out all wires connected good. Couldnt fix it yesterday. This morning I go in and everything is working. As it fixed itself overnight. I started tested everyhting and all good. When testting the switch in the middle to open the hatch was working good also but after 5 times testing that switch all of a sudden all the accesories on that circuit died again. Checked for the fuse and its intact. No logical explanation why it fixed itself. Is there something else I can check? Is there a relay for this circuit and if so where? Why would it fix itself and then die if the fuse is never blown. A short with blow the circuit. Please help I have tried everything and still acting up...
Old Sep 18, 2009 | 09:32 PM
feydeykin's Avatar
Re: low beams, hatch motor, interior lights wont work
I was wondering If somebody could send me a diagram of the circuit that controls the low beams, power locks, interior lights, hatch motor etc. I think its the circuit for accesories or at least thats the name for the fuse in the fuse box its under. I am thinking with the diagram to follow all the cables see if I find the culprit. Mostly to check if there is a relay for this circuit. Thanks for any help.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
1nastygta
Aug 8, 2015 07:38 PM
