Speed Sensor Compatibility
Old Sep 23, 2009 | 02:17 PM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
Would I be able to take the speed sensor off my '91 RS Camaro and install it in my '86 Trans Am? They both appear to be electric gauges. There isn't a speed sensor in the Trans Am at the moment, but there is one in the Camaro that has a bad transmission anyways. Just wondering if I could take it out and put it in the Trans Am.
Old Sep 23, 2009 | 05:02 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Speed Sensor Compatibility
TBI VSS should be a 2,000ppm unit as well as the older TA
You should be ok. The connectors will be different thou
http://i150.photobucket.com/albums/s...p/DSC01396.jpg
The TA will use the left connector and the RS will use the right connector
Old Sep 23, 2009 | 05:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Take the connector with the sensor... Be warned that you may have to cross the wires to get it to work (yellow to purple and purple to yellow).
Old Sep 24, 2009 | 08:52 AM
Car: '86 Trans Am
Engine: 305 H.O.
If I have to splice the wires, that's fine. Wouldn't be the first time I've had to do it.
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
