HELP!!!! With Headlights
Old Sep 26, 2009 | 10:47 AM
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
Hello,
i got a slight problem with my headlights.
when i turn on my low beams after about 2 mins my highbeams light up but very very dim. it has to be real dark out to see them. i was wondering what it could be. possibly a bad ground somewhere but i do not kno where to start looking.
please need some help it makes my low beams dim almost to the point of not being able to see when i am driving
Old Sep 26, 2009 | 11:17 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: HELP!!!! With Headlights
Yea that's what I'd do--check the grounds. IDK where they all are but also chk the bat ground cable//post and the ground strap from motor to body//chassis.
IDK how to check the hi-low selector but did it work correctly last time you used it?
You'll likely get educated answers rather than my rambling--GOOD LUCK.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
