1994 Fleetwood LT1 harness on 1996 Impalla SS LT1
Old Sep 26, 2009 | 08:45 PM
Hardkor455's Avatar
Can I use a 1994 Fleetwood LT1 wiring harness computer on 1996 Impalla SS LT1 motor? Or am I in way to deep. The 1994 motor was complete with accessories / harness / and computer, but had a cracked head. The 1996 one did not have the harness or computer but appears in good condition.
Also, the 1996 motor has the 460LE that came with it. How do I tell if what came with the Fleetwood? Is it in the partial "VIN" on the block?
This will be my first LT1 transplant, and it's supposed to go in a 1967 Cutlass. Any relevant information would be greatly appreciated.
Old Sep 28, 2009 | 10:52 PM
n4b's Avatar
n4b
Re: 1994 Fleetwood LT1 harness on 1996 Impalla SS LT1
I just installed a 95 LT1 into my 96 camaro, I used the 95 harness, Computer and transmission, The problem I had was that the car would not start because the harness is different, I then had to use the 96 harness on the 95 motor with the 96 computer, The car now runs and drive but because the 96 came with the front drive crank trigger, I now have to figure out a way to either put a wheel on the damper or get some kind of signal delete.
I would go with the 96 if you have the engine harness but be careful using different harnesses, You may run into the same problem.
This should help you get started.
http://web.camaross.com/forums/showthread.php?t=474185
Old Sep 29, 2009 | 09:51 PM
Hardkor455's Avatar
Here are a few pics of connectors I am still having trouble figuring out. Anyone know what this is:?
1.
2.
3.
4.
5.
Old Sep 29, 2009 | 09:54 PM
Hardkor455's Avatar
Also...
6.
7.
8.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
L0tuS
Oct 4, 2015 08:07 AM
jerflash
Sep 24, 2015 03:11 PM
mygta87
Sep 14, 2015 10:36 PM
L0tuS
Sep 4, 2015 11:16 PM
