LT1 no spark?
Old Sep 30, 2009 | 01:47 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
LT1 no spark?
I have a issue maybe someone can help me with.I have no spark going to the dizzy and i get a "check gauge" on the cluster.The cars a 95 caprice and I just replaced the coil and still nothing.Is there anyway to check the control module to see if thats it or does anybody have any suggestions they will be highly appreciated thanks.
Old Oct 3, 2009 | 08:50 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: LT1 no spark?
Yea, the ICM could be the culprit and there is a test...below is the link to one of LT1 sites I use for my '93 LT1...also the link to the test page from a page of great info. for LT1's shbox:
http://www.ls1tech.com/forums/lt1-lt4-modifications-31/
http://shbox.com/page/index.html
TGO is great for info, but the above two are also good help sites for Q & A on LT specific stuff.
The opti and the ICM tend to be the culprits for this issue...ICM being the cheapest at like $80...the opti being $250 for the cheapest GM one we can find on Ebay. If it ends up being the ICM, you may want to do the spacing mod for it when you replace it. Basically, you space it off the head some so some air is between the ICM/coil plate/bracket and the head...basically keeps it a bit cooler. Which is always better for electronics.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
