no spark from coil please help
Old Oct 16, 2009 | 12:54 AM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
i have a 305 z28 and i just swapped cam's. now i have no spark from the coil. all my grounds are good that i know of. i have 4 on the passenger side head and 3 on the driver head. the 3 and 4 wire plug in the dist... the 2, 2 wire plugs in the coil. still no spark from coil. the coil is brand new. please help
Old Oct 16, 2009 | 10:48 AM
JIMMY91's Avatar
Car: 91 R/S - IROC-Z SUSPENSION
Engine: 1970 350 LT1 BORED 30 OVER -355/
Transmission: 5 SPEED
Axle/Gears: 3.73 12 BOLT POSI
Re: no spark from coil please help
CHECK ALL CONNECTIONS.
Old Oct 16, 2009 | 02:10 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
i did. i made sure everything was tight. do you think the ignition control moduale went bad? im trying to get this running today.
Old Oct 16, 2009 | 04:10 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
You can pull the HEI module and take it to checkers/autozone and they can test it so you can rule that out as being the problem.
Old Oct 16, 2009 | 04:53 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
i will do that right now thanks. if thats not the problem then what would it be?
Old Oct 16, 2009 | 05:03 PM
JIMMY91's Avatar
What kind of coil do you have ? a external coil or the HEI in cap style ?
Old Oct 16, 2009 | 06:59 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
i have both. hei inside cap and coil on outside. just replaced hei. and coil tested good.
Old Oct 16, 2009 | 08:35 PM
JIMMY91's Avatar
You can't have both . I think you mean you have the hei cap with the coil on the top. If the coil is good ,I would say you either did not install the copper ground strap that is part of the coil the metal strap gets connected to the coils frame and is grounded through the connecter. Or you broke a wire somewhere in the connector wire back track the wires .Check your power going to the distributor at the connecter that says Batt. next to the tach connector..........
Old Oct 16, 2009 | 11:13 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
no....the hei module is inside the cap below the rotor. and the coil is mounted next to the dist on the outside...i checked the wires going to my starter, and they all have power. im not getting a pulse reading out of coil.
Old Oct 17, 2009 | 09:32 PM
JIMMY91's Avatar
Then you have a external coil like I asked earlier. Do you have power going to coil ?Trace the wires from the coil connector plug (not the starter wires) something got knocked loose.........or broken connecter somewhere.........if you can't find the problem ,call a hook and get it to a mechanic...............
Old Oct 17, 2009 | 09:37 PM
JIMMY91's Avatar
post some pics of your dist and coil ................
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
