Tail lights not working!!!! help!!!!!!!!!!!
Car: 1985 chevy camaro
Engine: V8 305 5.0
Hi, i have a 92 RS and it use to have a v6 but the guy i bought it from put in a carbed, 350 V8. and and when i bought it from him he was 98% with putting everything back. so now, nothing on the gauge cluster work (but that's the least of my worries) and my tail lights wont come on. they don't even make that clicking noise. the bulbs and fuses look fine. anybody has an idea on what it could be??
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Tail lights not working!!!! help!!!!!!!!!!!
Engine: V8 305 5.0
well, the light in my dash works and so do my brake lights. also my headlights work to (just not my high beams) u think its the fuse?
what about your side marker lights, tag lights and your front parking lights do they work
and you say your dash light (gauges, HVAC) light up when you turn on your lights
does the high beam indicator come on when you click your highs on
Engine: V8 305 5.0
On the cluster, the only thing that works is the bulbs that light up all the gauges, nothing else. i never really checked to see if my other lights work but i just know the only thing that works is my head lights & brake lights. but for now, i just need my signal lights working so i can drive it on the road.
if your turns and highs dont work its your multi function switch, or the conector for it, its in your colum, the conector is under the dash parts under the colum
if only your headlights work and your tail side marker and tag lights dont work then its a fuse or your headlight switch
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
