speeometer starts to work after 10 or 20 miles
Old Nov 11, 2009 | 04:39 PM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
Hey guys
my speedometer did not work before, use to flutter a little when driven for long times, I did not accumulate mileage for over a 1 1/2 years. did some VSS reserch on this site and came to the conclusion that the culprit was the VSS on the tranny. I removed the VSS and WHALA! the burgundy gear insde was grounded smooth, easy enough. I purchased 37 teeth gear for $11, swapped gears put back VSS filled up with 2 LUCAS trans slip fix and a gallon and half of walmart trans fluid. it's all good right now. I warmed up car for 20 minutes, did some easy shifting on a flat road(to get fluid to all nooks and crannies of tranny) drove off down 295. the speedo was fluttering but at 40 to 80mph, still good. after 45 minutes, 2100 rpm, the speedo focused on 74mph. Yeah Baby! So I got my speedo working. Not!
when I drove back home on local roads, speedo started boucin up and down below 30mph. thats odd. drove car 2 days later and now speedo does not work till after 20 miles and several bumps later. I have not removed the VSS to see gear status, I was thinking that Buffer box or computer should be replaced to get speddo to work.
What do you guys think?
Old Nov 12, 2009 | 03:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Need 4 Speed - O - Meter
You can monitor the output of the VSS with an oscilloscope to make sure it’s putting out a steady signal.
An audio amplifier can be used if you don’t have a scope.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 14, 2009 | 05:39 PM
Car: 86 Trans Am
Axle/Gears: Normal
Re: The Need 4 Speed - O - Meter
how do you use an audio amplifier?
Old Nov 16, 2009 | 03:47 PM
handeyman's Avatar
Similar problem happened to my car, the buffer box was the culprit for me.
Old Nov 16, 2009 | 04:13 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: speeometer starts to work after 10 or 20 miles
my speedo has its good and bad days. lemme know what you find.
Old Nov 17, 2009 | 01:13 PM
NINÅ's Avatar
Transmission: 765R4
Connect the amp’s input to the output of the VSS as you would a CD player.
Ground to ground, the signal wire to the inner wire of the audio amplifier wire.
When driving, or simulating VIA having the car jacked up, you will hear a hum which increases in pitch when the wheels are turning faster, if the VSS is good.
Use a spare old beat-up amplifier, you wouldn’t want to damage (in case something goes wrong) a top of the line amp.
Happy Racing!
Old Nov 19, 2009 | 07:30 AM
DANNY25SS's Avatar
Car: 92' Formula T-Top
Engine: L98 With Custom CAI
Transmission: BUILT 700R4 with B&M Mods
where and what is the buffer box my 91 rs does the same?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
